2.2 RhinoCAD – Reduce Mesh
Rhino works in much the same way to reduce mesh complexity. The command that will perform this task is called “ReduceMesh”. The Geometry is shown, imported into RhinoCAD. Note, this method of reducing geometric complexity may not work as well with large complex files and can cause rhino to crash.
FIGURE 5 - RHINO - IMPORT OF STL
